383 afr heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2012, 08:18 PM
383 afr heads
finally took her to the track 10.5-1 383 afr 195 heads eddy rpm 373 gears 245/45/17 nitto drag radials thru the pipes and spinning 11.90 at 113 mph complete street form as you can tell im very happy with the afr heads
Old 04-24-2012, 05:57 AM
11's is hauling a** for a street car in street trim. GREAT job!
Old 04-24-2012, 12:00 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
No technical questions in the thread, moving to the lounge.
Semper Fi
Old 04-27-2012, 10:08 PM
383 afr heads
thnx i was really worried about the little 10 bolt 3.73 8.2 rear end it has moser axles and aurburn posi and girdle cover but i figured if i went with slicks i wd be putting a bed side on her after the axle broke so until i get my rear disc brakes on i'll stay with drag radials lol and a thumbs up to the howards hydro roller 241-247 cam its working good i guess its around 500 hp seems like it car is 3600lb with me in it
383 AFR heads tuning question CAD Engine 3 04-29-2012 08:05 AM
blow by new 383 stroker AFR heads Tmouse Engine 7 04-28-2012 12:55 AM
383 withe afr 195 heads 241-247 howards retro roller 65elky Hotrodding Basics 3 01-05-2012 07:39 PM
afr heads on a 383 stroker 71chev Engine 10 02-12-2010 03:42 PM
FS: 383 with AFR Heads just built $2375 reserve elukas Engine 0 02-22-2004 01:07 AM
