383 Balance Qurstion - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2007, 02:42 PM
Hi i have a 383 but i do not know all the components. i had this engine built and installed at a speed shop in south florida. after 2 months i picked the truck up barely running.
anyway after getting it relativly fixed by reading a lot on the forum thanx!!! i have a question.......the flexplate has a weight bolted on it..so i thought externally balanced but the harmonic balancer has no weights....the engine does not vibrate but the flexplate looks to be in bad condition. what do you think?? leave it and run the way it is? change the flex plate? which one would i put in a weighted?
350 2 piece rear seal
383 crank
350 rods
H860cp 040
crane http://www.cranecams.com/?show=brows...64&lvl=2&prt=5
dart iron 72CC 180 runner
750 holley vacuum
wieland action + intake
ebay distributor
700r4 trans
Old 02-26-2007, 08:19 PM
balancer
Did you look on the backside of the balancer ,if it is a 400 balancer it will have a weight on the inside .If they balanced with the 350 balancer they would have had to add a bunch of weight to the crank .I guess it could be done.
Old 02-26-2007, 08:49 PM
i pulled the engine.....as far as the flexplate it is an externally balanced but it has a second added weight opposite the factory welded weight........
Old 02-26-2007, 09:41 PM
techinspector1's Avatar
Wiki Edits: 326
I'd be thinkin' it's an internally balanced motor and if I was gonna replace the flexplate, I'd get a 350 'plate.
Old 02-27-2007, 04:45 AM
Please do not screw around with this by taking the best guess approach.
Do either: Call the original builder/balancer and hope he kept notes.
Or
Take the flexplate to your local balancing shop. They can (or should be able to) spin up and measure the old one and then match balance a new one for you.
Have a safe race
Dave Koehler
www.koehlerinjection.com
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 08:08 PM
383 Stoker vs 383 Chrysler Jag Daddy Engine 100 08-14-2008 11:48 AM
383 stroker balance CAMARO Engine 23 03-14-2007 08:38 PM
383 external balance question ljjjrome Engine 24 01-18-2007 08:31 PM
383 Balance Question crusherdbuzz Engine 7 04-29-2006 11:04 PM
