383 Balancing Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2010, 11:27 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
I have a chance to pick up a built 383 short block. It has been internally balanced and has no harmaonic balancer or flex plate installed. Currently I have a 350 with a stock style balancer and I also am using a flywheel as it is a stick truck. Can I reuse the balancer and fly wheel that I have? or should I look to have these matched somehow to the 383? What are some considerations here, as I said the 383 is completely assembled
Thanks Folks
Old 03-09-2010, 01:02 PM
327NUT's Avatar
If you are SURE it is internally balanced and don't want to tear it down to have the entire reciprocating assembly balanced then I would not use the stock parts you have. If this short block is pretty potent then for safety's sake I would buy GOOD SFI parts. Take the SFI parts to a good balancing shop and tell them what you're doing. They can zero balance them if necessary....then cross your fingers when you wing it the first time.
Old 03-09-2010, 04:02 PM
I believe it makes a difference if your using a one piece rear main seal engine, or an older two piece rear main seal engine. They have different mounting flanges on the crank, and won't swap if I'm not mistaken.
ssmonty
Old 03-10-2010, 12:20 AM
ericnova72's Avatar
More for Less Racer
If it is internal balance you are correct. Use you flywheel, but I would recommend a new balancer, even a new stocker or stock replacement, rather than your old balancer if you don't need the SFI rated parts for racing.
Old 03-10-2010, 06:38 AM
Custom10's Avatar
OK..the 383 is a two piece real seal motor as well as my 350. I am sure that the 383 is internally balanced so maybe a new balancer would be in order and I can use my exisitng flywheel. This is not going to be a race motor so SFI would be nice but not needed here...yet. Thanks all
Old 03-10-2010, 01:56 PM
327NUT's Avatar
Before you have it balanced I would have the flywheel surfaced, get rid of any unseen heat checks. Its cheap to have done and that way when its installed and ready to dump the clutch you will have a good clean level surface to engage......just a thought.
Old 03-11-2010, 08:12 AM
Custom10's Avatar
Roger that..327
383 Chevy Question KGRIFF Engine 1 08-20-2008 04:33 PM
383 SBC pic and intake mani question. sexypizzaman Engine 9 02-04-2008 08:20 AM
383 balancing questions. TVR383 Engine 17 12-06-2005 03:23 PM
383 flywheel choice question undy Engine 7 09-26-2005 06:32 AM
engine balancing question. engineman302 Engine 4 05-27-2005 12:41 PM
