Thread Tools Search this Thread share on Facebook
  #1
Old 08-27-2007, 08:08 AM
F3RR3T F3RR3T is offline
383 block
i went and bought a block im going to go have her cleaned up etc etc.
what do i need to clearance and how much and where?
is there a write up some where
Register now (free) or login to remove ads
Old 08-27-2007, 12:44 PM
327NUT's Avatar
327NUT 327NUT is offline
There's probably a hundred or so 383 clearancing threads, you can do a search for those but you are mainly looking for rod bolt clearance in the block and clearance for the cam. Theres usually not a lot of grinding to be done and you may have to use a small base circle cam. Do a lot of research before you start putting things together so you don't have a costly mistake.
Old 08-27-2007, 01:12 PM
383silverado's Avatar
383silverado 383silverado is offline
can you see the notches right by the oil pan rails on both side?
Old 08-28-2007, 12:25 AM
fiscus fiscus is offline
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
My 383 didn't need any clearancing on the block, only on two of the connecting rods so they didn't hit the cam. I think it is a little different for each motor. Check out the pictures here: http://www.nastyz28.com/forum/showt...ght=stroker+101
EDIT: these are someone else's pictures not mine.
Old 08-28-2007, 08:45 AM
correct me if im wrong but how in the hell can a rod hit the cam
Old 08-28-2007, 09:13 AM
Holder350's Avatar
Holder350 Holder350 is offline
Auto Parts Professional
The longer rod puts it closer to the cam especially if you have a high lift. not an uncommon problem with strokers.
To clarify if you look "up" into the motor you will see that the bottom of the cam is "open" and as the con rod moves by it it sometimes hits, it shouldn't hit on the base circle of the cam but if the lift is enough you may have clearance issues.
Old 08-28-2007, 10:13 AM
hotrodf1's Avatar
hotrodf1 hotrodf1 is offline
Chasing dreams with a ball bat
Also note:
Many H-beam con rods are "profiled" for more cam clearance to help in that area. If look at one from the side I think you will see what I am talking about.
Of course, the small base circle cams can help, too.
I did my 406 (same stroke as a 383), and had to clearence the block a little, but I had a small base circle cam and profiled H-beam rods so no problem there.
Old 08-28-2007, 06:17 PM
i used a standard base circle cam (1.100 inches ) because i already had it before i built my 383.and my H beam rods cleared just fine. but it wouldn't be a bad idea to go with a small base circle cam. you'll just need longer pushrods.
Old 08-28-2007, 07:46 PM
glen242 glen242 is offline
Assemble and the you or your machinist check clearances.
383 with SIR 5.7 rods with cap screws had no problems clearince CC XE274 cam with std. base circle. A couple of cylinders need help at th bottom of the bores (3.75 stroke). Oil pan side rails needed clearancing.
You or machinist HAS to check everything before starting the engine.
Old 08-28-2007, 08:09 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
Location: In da woods, Union County, North Carolina, USA
Wiki Edits: 326
Also check clearance between the pin end balance pad on the rod and the underside of the piston. Of course, this should be checked on every build, I'm just throwing it in while we're talking checkin' clearances. I keep a wrist pin on the shelf for this operation that I sanded down to a slightly smaller diameter so that it will just slide through the piston and rod.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "383 block"
ThreadThread StarterForumRepliesLast Post
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reasonkillerformulaEngine29805-21-2012 02:14 AM
the history of chevy v8'ssavman1Hotrodders' Lounge4303-02-2012 06:57 PM
SBC Strokers - 350 vs 400 Blocks & Combos (not just 383 & 406)ez2cdaveEngine1105-21-2007 09:34 PM
Big block questions, help please???67 sleeperEngine2005-15-2007 04:24 PM
Why would you build a 383 small block chevy454meEngine1506-19-2005 07:23 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
