Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 block selection
Old 05-02-2012, 07:42 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by ap72
Well a hydraulic roller cam will do you a lot more good than a stroker crank, so I'd either pull the roller block you have, spend the extra money on a better block, or spend more money on a hydraulic roller conversion kit.
x2. I just swapped my flat tappet cam for a roller cam with less duration and its so much tamer. Better idle quality more vacuum and wow it pulls much harder than the other cam. I am done wasting my time with flat tappet cams.
