Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 block selection
Old 05-02-2012, 09:02 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by ap72
You installed that cam from howards right? Which one was it again? How would youdescribe the drivability? Vacuum at idle? Idle speed? Where does it fall off?
180325-08. It has more power down low for sure compared to the other cam I had in it which helps it get moving. I get about 13-15" at 1000rpm but im having issues with ring seal and valve seals so I imagine once I get the motor tight I will retest. It makes driving around town easier. I haven't ran it past 6000rpm yet but it doesn't give up at 6k.
