Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 block selection
Old 05-02-2012, 09:21 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by louis165
How is the valve train noise ?
Not bad I mean I had some issues with some of my rocker studs backing out causing excess clearance and making noise but once I adjusted them correctly they are fine. Im using the factory hydraulic roller lifters from a vortec engine.
Originally Posted by ap72
15"?! Id imagine you can turn that idle down some, maybe 7-800 rpm.
I had it at 750-800 but when I put it in gear the vacuum needle would start jumping around along with the idle and die. Most likely a tuning issue but it has plenty of initial timing so im assuming a little too rich.
