383 block selection
I have a 350 block from early 90s . none roller . 2 bolt .casting #10054727 ( canda ) block will this block hold up for a 383 stroker build with 10.1 comp
Yes, it could handle it with proper machining and parts selection, but WHY? A used 4 bolt roller block with std bore is like $200? WELL worth it IMO. |
I have not been able to locate another roller block and I didn't want to pull mine out until I had one ready to go back in .. they have sold all the junk iron around my area..the good with the bad .
Well a hydraulic roller cam will do you a lot more good than a stroker crank, so I'd either pull the roller block you have, spend the extra money on a better block, or spend more money on a hydraulic roller conversion kit. |
Thanks guys I just wrapped it up and pushed it to the back corner . the roller cams are nice mine has no lope so they think it is a stock 350 . Thanks guys
| All times are GMT -6. The time now is 04:16 PM. |
