383 blower - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2007, 05:12 PM
chevrolet327's Avatar
second place is the first losr
Last journal entry: old stlyle holley polished valve cover
383 blower
just want to know if someone try 142 blower on a 383 im building this for a friend he have 18 cc dished hyper piston is it ok for run on pump gaz with 64 cc aluminium head he can also have 28cc dish piston
Old 10-27-2007, 05:26 PM
Notorious's Avatar
Hot rodder, not street rodder!
Personally I wouldn't go with anything less than a forged piston with forced induction. I only like to build engines once.
Old 10-27-2007, 05:30 PM
ok i anyway i think he need more dished piston to run on pump gaz im check for a forged set thanks
Old 10-27-2007, 07:12 PM
thank you very much f bird88 that exactly what i want to know im going to install this motor in a off road truck with 44 tire do you thinks the guy will be happy i dont what kind of low end torque a supercharger give
Old 10-27-2007, 08:03 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Have you thought about using a 177 in place of the 142? I know the owners manual says that a 142 on a stock 350 is good for about 6 psi and about 4 psi on a 400. A 177 might be a better choice for a 383.
Old 10-27-2007, 08:26 PM
does the 177 use a single 4 bbl ?
Old 10-27-2007, 08:34 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
yes it does. I tried a 142 (or 144, been a while) on a 400 that was warmed over and could only pull 2 lbs of boost. needless to say I wasn't happy. go to the 177 like blazin recommended if you can.
Old 10-27-2007, 09:23 PM
Blazin72's Avatar
Wiki Edits: 19
Superchargers
blower idle rpm problem Ratoflic Engine 7 12-01-2008 03:31 AM
6-71 blower 383 build Johnny4311 Engine 6 07-20-2007 06:41 AM
chevy small block 383 blower motor blk man Engine 3 03-31-2006 07:26 PM
383 chrysler blower manifold los loco Engine 1 10-20-2005 10:42 AM
Toyota Camry Blower Motor Problems donemore2003 Electrical 12 11-11-2004 10:45 PM
