383 bog - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-11-2009, 09:53 PM
ericnova72's Avatar
More for Less Racer
Ouch!
I feel for you, been through all the same things after an freak accident(jumpy dog), two days AFTER a cornea tranplant, which broke the stitches and the pupil constricter muscle. The non-dialating pupilary muscle is the worst thing left, a real bother on bright sunny days. I was just glad they could save the eye.
Hang in there
  #17 (permalink)
Old 06-11-2009, 11:35 PM
Sorry to hear about your accident. A few years ago I got nailed in the eye by some piece of something I wasn't even doing anything and it tore the white, it was red, and white, and was my 'good eye'. Bad eye? Well, it's all good really, but for the 'spot'. Flourescene? angiogram, retina pics, tests tests and tests bla bla bla and notta. Probably brain or nerve damage Was in a motorcycle wreck, and car wreck same year. It's been that way for like 25 years, and only noticeable when say look at an LED, just above and left of center and it disappears. I wear glasses when I go out of the house because I never want an eye issue again, and as you can affirm, it only takes a second. One more eye deal. A buddy I grew up with, his sister stuck a screwdriver in his eye when he was like 7. He's 52 now, and has the cat eye, or snake eye. His pupil is not round but like this () and pointy top and bottom, he has no eye or vision problems to date. Hope you come out OK. Sorry for the blabber.
  #18 (permalink)
Old 06-13-2009, 01:08 PM
stanjr41's Avatar
383 bog
Thanks for the support. It's easy to be overwhelmed by a car problem and take things for granted-especially safety. I drilled a hole in the screwdriver and it now hangs from my mirror as reminder. My son replaced my converter with a 3000 stall. It revs so quickly there is no bog. But I know it's not right. We borrowed an O2 sensor and installed it in the exhaust. At idle in gear it reads 11.5; at 2000 it's 13.1. The stock jetting is back in.Also;after talking to the tech at MSD I found out that there is a vac fitting on the bottom of the dist. If you don't know where to look you'd never see it. After hooking it up I was able to set the timing properly. Without that; the dist. was only showing mechanical, and no vac. Much better! Any ideas on the O2 settings?
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 08:08 PM
383 stroker v.s. 383 chrysler ...the end mcharger440 Engine 58 12-07-2012 08:16 AM
383 Stoker vs 383 Chrysler Jag Daddy Engine 100 08-14-2008 11:48 AM
Supercharging and fuel injecting a 383 Chevy Noesis Engine 11 09-21-2007 05:51 AM
383 0r 406??? Zubair Engine 60 10-14-2005 07:53 PM
