383 bore size question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2007, 03:25 PM
mattson70's Avatar
Without knowing my exact bore size how do I go about buying head gaskets for my 383 stroker motor?
Old 02-05-2007, 04:02 PM
Whippetguy's Avatar
Last journal entry: Window templates
Same as stock 350. The added displacement comes by way of the longer stroke, usually from a 400 crank. The bore remains the same.
Old 02-05-2007, 05:14 PM
mattson70's Avatar
OK, thanks. I looked at Fel-Pro head gaskets on summit's site and they list several different bore sizes for the 350 chevy motor. What is the stock bore size?
Old 02-05-2007, 05:31 PM
RippinRon's Avatar
A stock 350 bore size is 4.00". Most head gaskets available are usually larger I think 4.166 is a pretty standard size. A larger the diameter will decrease the compression ratio marginally and off course a smaller one increases it.
Old 02-05-2007, 05:32 PM
kuhn-77's Avatar
Build it right the first time
If you want to get technical about it:
#'s in Bore x Stoke Relationship
A stock 350 is 4.000 x 3.48
A 377 Can either be a stock 350 block with a 3.75 stoke crank 4.000 x 3.75, or it can be a 400 block bored .030 over with a 3.48 stroke crank 4.155 x 3.48
A 383 Can be either a 350 block bored .030 over with a 3.75 stroke crank 4.030 x 3.75, or it can be a 400 block bored .060 over with a 3.48 stroke crank 4.185 x 3.48
A 385 is a 350 block bored .040 over with a 3.75 stroke crank 4.040 x 3.75
A 388 is a 350 block bored .060 over with a 3.75 stroke crank 4.060 x 3.75
So if its a 350 block, and its in fact a 383 then the bore is 4.030.
Hope this clears things up and gives you some info for later on.
Old 02-05-2007, 05:36 PM
mattson70's Avatar
Thank you. That clears things up nicely.
Question about 383 stroker.. XxChevyGirlxX Engine 5 09-05-2006 06:40 PM
383 mopar with procharger intake question mychevystang Engine 2 08-30-2006 06:10 PM
newbee question about 383 build jgaona Hotrodding Basics 5 08-17-2006 03:03 PM
355, 377, 383 or 406? That is the question! newchevyman Engine 26 05-16-2006 07:15 AM
Chevy 383 / Flexplate Question fiftysix Chevy Engine 3 03-02-2006 06:23 PM
