Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 build
Thread: 383 build
Old 03-01-2013, 10:53 PM
bjautos7's Avatar
bjautos7 bjautos7 is offline
this is a photo of the rods that going in. what i like about this rod is it's a 6 " with 7/16 bolt and stroker cleared. only had to clean up bottom of the bore a little and pan rail was sweet. if you look at the piston you can see it use's a skinner oil ring and the pistons pin don't go all the way in the oil ring landing like ofters do.
