383 build
hello,
so im back to the drawing board. i got the 350 block back from the machine shop so the only thing left is to hone it for the pistons. my goal is to hit the 500 hp mark. this is what im thinking http://www.summitracing.com/parts/SCA-1-90305BE http://www.summitracing.com/parts/AFR-1036 http://www.summitracing.com/parts/CCA-54-424-11 im not sure of what a good compression ratio for street use is but id like it to be somewhere close to it. also we only have 91 octane in the area. does anyone have any input or suggestions? |
Sounds like a good street package to me. Cam you linked is for the newer LS1/LS6 engines however, won't fit your block. The actual cam grind is just fine but you could go a little bigger if you want a hot rod engine rather than a plain daily driver.
what about this edlebrock cam......
http://www.summitracing.com/parts/EDL-22076 ive always heard good about comp cams but i came across this edlebrock cam. does anyone have any experience with these? |
thats the eddys roller cam rite? if so that would be a good one! they put that one in there crate engines makeing 420-430hp with e-tec and rpm heads with flattop pistons...rite?? with around 9.1-9.5cr??
| 383 build | Novaguy383 | Engine | 14 | 01-14-2012 01:21 PM |
| 350 vs 383 build for performance | Biscuit6447 | Hotrodding Basics | 20 | 03-05-2010 08:42 AM |
| help: is this 383 sbc build combo right? | fastlaners | Engine | 5 | 01-30-2010 08:36 PM |
| 383 Build questions | ekacpuc | Engine | 7 | 12-18-2009 08:21 AM |
| a budget 383 stroker build using a stock 400 GM Crank | Mustangsaly | Engine | 8 | 10-15-2007 12:57 PM |
