383 build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-02-2013, 12:46 AM
bjautos7's Avatar
here are some photos of other things i have done. tap at the front oil gallely holes.
  #17 (permalink)
Old 03-02-2013, 12:57 AM
bjautos7's Avatar
next was to clean up around the pump securing bolt on the rear main and blend it into the discharge hole leading into the block.
in the last photo i clean up entrance and exit holes in the oil filter location. the idea is to flow the oil passages so that the amount of oil pressure lost, as the oil progresses from the pump to the bearing is reduced.
  #18 (permalink)
Old 03-02-2013, 01:10 AM
bjautos7's Avatar
Originally Posted by 68NovaSS View Post
Moving this thread to the Projects/Builds forum.
why !!! this is not a project , this is a engine build so this should be under engines . form user's look for info about building engines. this make it hard to find
  #19 (permalink)
Old 03-02-2013, 06:46 AM
vinniekq2's Avatar
very nice heads.
  #20 (permalink)
Old 03-02-2013, 07:03 AM
vinniekq2's Avatar
moving?
I dont know why its being moved?
was the content wrong?
I would only look under "engine" or "hotrodding basics" for this type of article
Vin
  #21 (permalink)
Old 03-02-2013, 01:40 PM
bjautos7's Avatar
Originally Posted by vinniekq2 View Post
very nice heads.
thanks , yes very good heads, these one's are afr 195 with 65cc chambers.
  #22 (permalink)
Old 03-02-2013, 01:44 PM
bjautos7's Avatar
Vin
i feel the same way , as for my self i too look under engines and hotrodding basics for info and advice, from other menbers. i feel like they are missing out.
  #23 (permalink)
Old 03-02-2013, 10:34 PM
bjautos7's Avatar
hi every one , now i'm at the point too piant my block. block. what colour should i paint it. red , organe or black. what's the best way to clean the surface of the block before painting. has any one tryed carby cleaner or is there a better way.
  #24 (permalink)
Old 03-02-2013, 10:46 PM
vinniekq2's Avatar
brake cleans or equivalent is good.it evapourates quickly
  #25 (permalink)
Old 03-03-2013, 10:13 AM
BigMo's Avatar
what cam are you using with those heads? im putting together a similar motor for my coupe, using AFR 195/65 w comp. porting, and a CompCams roller.....around .560 lift
  #26 (permalink)
Old 03-03-2013, 11:52 AM
bjautos7's Avatar
as for cam it's a xr282hr. gross valve lift is .510 / .520 duration @50 230/236 intake center line 106.0 lobe separation 110.0 and with 1.6 roller rockers which make it 544/555 gross valve lift. which should make around 480-500hp at the flywheel and still be street friendly.
  #27 (permalink)
Old 03-05-2013, 06:15 PM
bjautos7's Avatar
thanks for the good info , had done the hot wash , spray with brake clean to clean the suface, then masked up and now all painted. here are some photos of how it come out.
  #28 (permalink)
Old 04-07-2013, 03:10 PM
bjautos7's Avatar
was looking at bearings to replace the ones i have. the part number on the one i have is ms909h which is a std bearing. now my clearces on the crank was to tight so which set do i get is it ms909h1 undersides or ms909hx smaller .
  #29 (permalink)
Old 04-07-2013, 03:32 PM
engineczar's Avatar
The X bearing will give you more clearance.
BSE Racing Engines
The Following User Says Thank You to engineczar For This Useful Post:
bjautos7 (04-07-2013)
  #30 (permalink)
Old 04-07-2013, 03:43 PM
engineczar's Avatar
Your build looks good. Only one observation, were the cam bearings installed when you tapped the oil plugs and ground the oil returns? I prefer to do all the fit ups and cutting with old cam bearings then remove them for the final cleaning. Crud tends to collect in the grooves behind them.
BSE Racing Engines
whats better 400 crank or a 383 crank in a 350 sbc when trying to build a 383? onlychevy Hotrodding Basics 14 12-28-2012 07:27 AM
383 build mgr64733930wo Introduce Yourself 2 07-10-2012 03:13 PM
i need a 383 build!! Ruger69 Engine 3 11-09-2011 02:06 PM
383 Build mannyandlily Hotrodding Basics 5 12-20-2009 09:12 PM
383 build reflog Engine 6 11-01-2006 08:28 AM
