383 build - Page 7 - Hot Rod Forum : Hotrodders Bulletin Board
  #91 (permalink)
Old 08-14-2013, 02:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
On the second page, along about 4200 rpm (just below the torque peak) the bsfc numbers begin to look 'meaningful'. bjautos7 said the air/fuel ratio was 13:1 @ idle and 11.8:1 @ wot, so maybe there's another page showing the a/f ratios.
  #92 (permalink)
Old 08-14-2013, 03:06 AM
bjautos7's Avatar
no other pages ,they wrote on the first page 13 idle and 11.80-12.00 which must be air flow ratio. they also put 76/83 jets and timing @ 32. I removed rocker covers and found I had to re-adjust the roller rocker as 3 of them was loose. I also strip down the carb to clean an it had 73 / 83 jets not 76 in the front bowl as stated.
  #93 (permalink)
Old 08-14-2013, 09:02 AM
Banned
you have way too much manifold vacuum through your pull too, with your carb wide open the vacuum should increase with rpm, not go down, and the most you're going to see on an engine like yours is 2-3" at peak power at WOT, if that much.
Sounds like this shop bought a used dyno and didn't want to bother learning how to use it, or calibrate it.
Also, sounds like the sold you a line of bull **** on the tune if they said 76 and you're pulling 73's out.
Your fuel consumption is WAY off, like not even close.
Your power was still rising when they shut it off, they should have at least taken it to 6,000 rpm, maybe a little more if you were comfortable with it. The reason your peak looks low is because you never hit your peak, its past 5500 rpm.
  #94 (permalink)
Old 08-14-2013, 05:46 PM
bjautos7's Avatar
have asked around and from what i can tell , not many people had any thing nice to say about them. one even say that they try to break the engine on the dyno so they can fix it. i did ask when was the last time they calibrate it and the answer i got was never. i should have known better but was to egger to put on the dyno.
  #95 (permalink)
Old 08-14-2013, 09:27 PM
vinniekq2's Avatar
drop the engine in the car and lets road test the beast? I hate wrong information or worse,misrepresentation! The parts are in the engine,,,,How did it sound?
  #96 (permalink)
Old 08-21-2013, 11:54 PM
bjautos7's Avatar
music to my ears , had a good strong sound. now looking for ute to fit it in. we have 1/8 street drags here in feb. so the plan now is to have it ready for then and have a play. also looking at adding a 100hp short of nos to.
  #97 (permalink)
Old 08-22-2013, 12:13 AM
vinniekq2's Avatar
I would love to see a video of w/e the vehicle that gets that engine. With a well matched drive train Im sure it will be fun
  #98 (permalink)
Old 01-07-2014, 12:47 AM
bjautos7's Avatar
hi every one , have changed plans and now fitting to a ea falcon , now look at what size wheels to run with. This is what I was thinking , 265/60/14 rear and 225/60/14 front and 3.45:1 diff ratio with 2500rpm still convertor in a 350 turbo trans. what do u guys think.
whats better 400 crank or a 383 crank in a 350 sbc when trying to build a 383? onlychevy Hotrodding Basics 14 12-28-2012 08:27 AM
383 build mgr64733930wo Introduce Yourself 2 07-10-2012 04:13 PM
i need a 383 build!! Ruger69 Engine 3 11-09-2011 03:06 PM
383 Build mannyandlily Hotrodding Basics 5 12-20-2009 10:12 PM
383 build reflog Engine 6 11-01-2006 09:28 AM
