383 build for e-85 fuel? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2010, 08:33 AM
Rectum? Damn Near Killed Um!
Just wondering what everyone thinks about building a 383 street motor to run e-85 fuel? What's heads, target compression, carb etc. Working on building a 383 to run 87-89 octane but just wondering if there would be any benefits from building for "flex fuel".
Old 12-12-2010, 01:59 PM
whatle's Avatar
If you build it for e85 it will run on e85 only because to take advantage of the higher octane fuel you will need to run higher compression and more timing. if it is readily available in your area i'd run it since its cheaper and you can make alot more power than 87/89 octane. i'm not sure what parts to use but i'm sure someone else here knows
Old 12-12-2010, 02:53 PM
CJ_1080's Avatar
known to do dumb stuff!!
You would need to use an alcohol carb, and steel fuel lines. Alcohol or E-85 will deteriorate rubber lines in short order. More compression and less timing would also be in order. I believe E-85 is between 104 and 110 octane depending on how long it is in the tank. The only problem Ive experienced is the fuel degrades fairly fast. It absorbs moisture out of the air (just like break fluid) so treating the fuel should be consitered manditory.
Marine 383 build mtnrat Engine 25 03-31-2014 06:47 PM
Speedfoos 383 Volvo Amazon Build speedfoos Hotrodders' Lounge 142 03-10-2011 09:37 AM
Planning the build of my first 383 396flyby Engine 1 09-20-2009 03:16 PM
DARK brown--BLACK plugs SBC Joshua Lee Engine 128 02-03-2008 09:12 AM
Octane Booster Info SLR_65 Engine 46 09-30-2007 09:01 AM
