Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 build (help need advise)
  #17 (permalink)
Old 05-13-2012, 04:06 PM
gofastz gofastz is offline
should be the same as a holley, set your floats like you would on a holley, see what size jets you have in it and what size power valve, too see what size power valve you need, take how much vacume the engine makes devide by 2 and that will get the size you need, now jets there should be a 6-8 spread like for instands 69 primarys 75-77's in the secondarys.. 200$ sounds like a great deal on that carb, and if your going to just street it no raceing id still go with the 5.7 rods alot of plp use the 6" rods for extreme raceing use, it will be a very happy motor with the 5.7 rods!
