383 build (help need advise) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-13-2012, 11:57 PM
Well I just ordered a 750hp carb so that problem is solved thanks again for all of your help guys, now I just gotta learn how to rebuild my tranny my local shop quoted me 1200 bucks to rebuild it "ouch"
  #17 (permalink)
Old 05-14-2012, 07:24 AM
For the trans check out the transmission forum here .1200 parts and labor sounds cheap .how ever your engine build should be over 450 HP so the trans will need GOOD parts
  #18 (permalink)
Old 07-04-2012, 07:48 PM
got the cam broke in
Hey guys,
Well i got the cam broke in and after that i was trying to get the timing fine tuned and i heard a tick tick from the right side of the motor???
At first i thought i had a exhaust leak but i could't find one so i took off the valve covers and started it back up!
I found that the #6 intake rocker isn't getting any oil what would cause that? I took off the rocker and the pushrod to make sure i had no plugged up passages and all was good there. So what now guys??? do i have a collapsed lifter or spun cam bearing? Im thinking of tapping on the pushrod while it is sitting on the lifter (maybe its stuck)?
p.s. happy 4th of july
