Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 build kits?
Thread: 383 build kits?
  #20 (permalink)
Old 11-13-2012, 11:23 PM
Camaro R/S LT Camaro R/S LT is offline
Originally Posted by vinniekq2 View Post
Its a start. Please explain why you want 1.6:1 rockers? They have a place,just not sure where on a mild engine.I use 1.6 rockers on my engine and a fairly big(for the street) solid roller cam. before you get those rockers,the first thing you need is a good set of heads. Take flow measurements to choose camshaft and figure what CR you need to make it all work
After reading up on it and seeing that they dont make a difference unless you're REALLY racing, I see your point since I'm going for a mild setup. I guess I initially thought that with the roller cam and more pressure from the .1 increase, it would create a little extra top end power with the 1.6s.
