Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 build kits?
Thread: 383 build kits?
  #25 (permalink)
Old 11-15-2012, 08:35 PM
cdminter59 cdminter59 is offline
383 build
Check out this 383 Scat rotating assembly. This rotating assembly is used in a 2pc rear main seal block. It is external balanced and comes with a balancer and flexplate. Scat Engine Rotating Assemblies 1-90355BE - SummitRacing.com. This assembly is for using 64cc chambered heads for a compression ratio of 9.7. Here is a 383 Scat rotating assembly for a 2pc rear main seal block. It is also external balanced and comes with a balancer and flexplate. SB Chevy 383 Scat Rotating Assembly Kit, 3.750 Stroke 5.700 Rods 9.8:1 Hypereutectic Keith Black Dish Pistons - 383 Kits with 5.7' Rods - 9000 Series Kits - Small Block Chevy - Scat Rotating Assembly kits - Rotating Assemblies | CNC Motorsports | Car. This kit also uses 64cc chambered heads for 9.8 compression ratio. Since you are going to have a stick shift transmission I also looked at this 383 Scat rotating assembly. It has 6" rods and Keith Black Hypereutectic 18cc Dish Pistons. This is an internal balanced assembly by CNC Motorsports. The balancer and flexplate (which is not needed) does not come with an internal balanced kit. It also uses 64cc chambered heads for a 9.8 compression ratio. SB Chevy 383 Scat Rotating Assembly Kit, 3.750 Stroke 6.000 Rods 9.8:1 Hypereutectic Keith Black Dish Pistons - 383 Kits with 6.0' Rods - 9000 Series Kits - Small Block Chevy - Scat Rotating Assembly kits - Rotating Assemblies | CNC Motorsports | Car.
The Following 2 Users Say Thank You to cdminter59 For This Useful Post:
Camaro R/S LT (11-15-2012), techinspector1 (11-15-2012)
