Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 build kits?
Thread: 383 build kits?
  #27 (permalink)
Old 11-17-2012, 07:14 AM
gearheadslife gearheadslife is offline
Banned
Originally Posted by Camaro R/S LT View Post
flat top or dished pistons: pros/cons?
if heads are already sourced then use what gives you the compression you need/want..
if heads are not already on hand and need to be bought..
flat top 99% of the time is the better choice.. and use the heads chamber size to get the compression you want... no always possable ..but mosttimes you're not reinventing the wheel.. and the parts needed are out there..
of cource I'm talking n/a, boosted is a totally different animal
