I know i'm asking a 100 questions, but i need to pick some minds that know, your help is appreciated ! ok so far i've ask about a 350 build , and a 377 build, but now wondering about a 383 build.
info on P/U it's going in
http://www.hotrodders.com/t63973.htm...ight=350+build
not a daily driver or hwy cruiser, 71 Chevy P/U 350 turbo tranny with stall converter & 373s rears
when building a 383 theres some block work that needs to be ground away or clearanced for the rotating assembly correct ? just have that done when block is machined / bored ? they should know where & how much ? i plan on reconditioning my 350 rods, then take the new crank in the northern auto parts kit, with flexplate and my ballancer down to machine shop and have it ballanced ?
this will have prob a roller rockers & an Edelbrock RPM Performer intake and 76cc cast iron heads, headers
ok questions
1. should i run a new harmonic balancer ? this place rebuilds used ones
http://damperdoctor.com/
2. what CR should i run ?
3. should i run a HV Oil Pump ?
4. below is whats in the kit, what cam would you run for this build
(cams for this kit are listed below)
HP383KHWHypereutectic Piston W/Crank
http://www.northernautoparts.com/Pro...?ProductId=549
Chevy 383 (350 Chevy using 400 crank & 5.7" rods) - HP383KHW Hypereutectic Piston W/Crank
INCLUDES
Federal Mogul Seal Power,or Hasting Moly Rings
Federal Mogul Hypereutectic flattop Piston
Clevite Rod Brgs
Clevite Main Brgs
Clevite Cam Brgs
Melling or Sealed Power Hi volume Oil Pump
Crane Energizer Camshaft and Lifters
Cloyes TRUE Roller Timing
Pioneer Frost Plugs
Felpro Gaskets
New Scat Crank using 5.7 Rods
Make: Chevy
Model: 350 Blk, 400 Crank, 5.7 Rods
HELP Me pick a cam
Crane Energizer Camshaft #100032 1200-4200RPM 260dur .472lift 110 lobe sep
Crane Energizer Camshaft #100042 1600-4600RPM 266dur .444lift 110 lobe sep
Crane Energizer Camshaft #100052 2000-5000RPM 272dur .454 lift 110 lobe sep
Crane Energizer Camshaft #100172 2200-5200RPM 274dur .450lift 106 lobe sep
Crane Energizer Camshaft #100132 2400-5400RPM .467lift .110 lobe sep
Crane Energizer Camshaft #100082 2500-5500RPM 282dur .470lift 106 lobe sep
Crane Energizer Camshaft #100072 3000-6000RPM 284dur .480lift 112 lobe sep
Crane Energizer Camshaft #100182 3200-6200RPM 286dur .465lift 106 lobe sep
Crane Energizer Camshaft #100112 3500-6500RPM 302dur .500lift lobe sep
