Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 Build Questions
Old 06-12-2005, 06:26 PM
GoneNova/406's Avatar
GoneNova/406 GoneNova/406 is offline
if you get a new crank and the the right rods you don't have to grind.if you have the machine shop do the other work,have them do the balancing and grinding because one will run into the other and you'll end up destrouing the balance job.its not that much and much simpilar if you let them do it even for me.if you don't know what you're doing its a must.
