383 build ?'s - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-15-2013, 09:05 PM
vinniekq2's Avatar
the best online CR calculator is techinspector1
Senior Curmudgeon
  #17 (permalink)
Old 04-17-2013, 11:28 PM
Ok, I'll throw another idea or wrench into the equation.
I think i'd like to keep the rotating assembly I have (12cc round dished pistons) and just decide on a head selection that will fit best with what I have. I will zero deck the block and use the felpro 0.041 thick head gasket for my quench. So that leaves me with using the 72cc sportsman ii iron heads for a CR of 9.4 or I could perhaps use a set of aftermarket aluminum vortec style heads 64cc that will give me 10.24 CR. What is the best choice? More CR and the aluminum heads or lower CR and iron heads? Thanks.
  #18 (permalink)
Old 04-17-2013, 11:45 PM
vinniekq2's Avatar
the camshaft needs to match the "head flow" and cr. You need to determine the HP required.Then decide the engine size you want. The math involved matching head flow to make the HP and the rpm needed for your engine to use all the flow,,,it all counts,not just alloy/cast iron and dcr.
your fuel air flow management needs to match and the exhaust needs to breathe the correct amount
to para phrase tech,its the total combination,,,
whats better 400 crank or a 383 crank in a 350 sbc when trying to build a 383? onlychevy Hotrodding Basics 14 12-28-2012 08:27 AM
383 build Novaguy383 Engine 14 01-14-2012 02:21 PM
Yet another 383 build Jerry's 63 C10 Engine 4 10-15-2011 06:44 PM
383 build strokin Engine 2 05-09-2011 01:22 AM
383 build bigkevy Engine 6 07-23-2010 10:19 PM
