David Vizards article "pocket change stroker" suggests the use of a cam with a 108 lobe centerline, as it will benefit the 383`s power band. Isky Cams offers a wide selection of 108 centerline cams. i`d go with a cam with 224 - 228 duration @050, but keep in mind you`ll need a stall converter if your running a automatic with a cam slightly over 224 duration. a 700 to 750cfm carb will suit your combo fine. I wouldn`t worry with 400 horses, on the street i`d want 400 ft lbs of torque, and torque is what the 383 does best, it`s not often you`ll be revving it on the street, and horsepower is upper RPM power, torque is what you feel out of the hole.
