Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 cam change internal clearance questions
  #17 (permalink)
Old 10-24-2012, 08:27 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
couple typos, trailing "arms" and 1962 technology not 1062,sorry. the 1963 corvette has the same suspension we have now.
Also if you have the low profile hood I have to assume your car is down on power as there is not enough room under the hood for a good intake.
You can put 3 inch exhaust through the transmission x member if you do not have side piped
