Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 Cam Swap. Thoughts? More Streetable...
  #27 (permalink)
Old 10-25-2012, 09:15 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
I would change the cam to a summit cam #1103 if you want to use a stock 2100 stall 12" converter and
drop the gears down.
214-224-.442-.465 112 LSA good idle, good fuel mileage, good cruise, good power right from idle to 5500 rpm.
You will find this much more civil in daily driving yest makes very good power when you rug it.
Fine with a stock converter. 3.08 to 3.55 gears are fine in your light car.
The car is light weight . Its still going to GLH.
I had this cam in my 350 vortec motor with 3.42's. Its a nice cam that works well.
How you design your exhaust system makes a big difference in how you enjoy driving the car.
I spent quite a bit of time doing mine. The mufflers are custom home hand built. The overall result was very good.
makes power yet doesn't drone or get old.
I agree with the other poster. Try just reducing the gear ratio, first. Your car is very light.
Then if you decide you also want a tamer more civil camshaft try a similar Isky cam #201264/271-12 "264/270 Mega Hyd"
Isky cams and lifters are high quality. This cam will still make a ton of power and torque in your V8 bug.
And cruise a lot more civil. 264/270 214-221@.050" .450"-.465" 112LSA
