383 carb swap to 4l60e - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2011, 08:52 PM
brad33478's Avatar
hi everyone this is my first post.
I am swapping a 383 carb stroker into my 07 silverado that has a 4l60e (& originally a 4.3l)
now i have a TPS adapter purchased for my holley and i was told the entire serpentine setup will transfer over from the old 4.3l
also told to remove the original purple wire from my dist. and attach it to the HEI tach slot for RPM input.
most/if not all of my sensors i can transfer over
my question is on the bellhousing/flexplate. im guessing the original flexplate will not match but i havent read anything on the bellhousing???
also what flexplate can be used to adapt to the tq convert?
thanks in advance
-Brad
Old 01-08-2012, 01:05 PM
gonzo08383's Avatar
Last journal entry: brakes
bell housing should match up, chevy v8's havent changed in that aspect for the last 40 years. unless you have an ls, i'm not familiar with those. have you thought about a stand alone controller from tci? 800 bucks but you can program your own shift points and line pressures. just a thought. good luck sir
Old 01-08-2012, 02:12 PM
brad33478's Avatar
i did look at the stand alone controllers but idk how long my 4l60e is going to last behind it so i may be going with a th400 or a donor 4l80e with tcu later on
Old 02-25-2012, 10:30 PM
brad33478's Avatar
well got everything all hooked up (TPS + CTS) and driving but I think it is in limp mode, seems to only start out in second and wont go into overdrive. I wired up the hei to the original white for the tach signal from my old coil like the wiring diagram said but still got nothing to the tachometer. could having no crank position sensor cause the tach signal to not properly run through the computer? Im hoping thats the main reason for the trans.
if so do they make a CPS adapter to mount one on a gen 1 block?
Old 02-26-2012, 09:24 AM
rick 427's Avatar
Last journal entry: 33 WILLYS
don't know what they cost...but it's free to check out the PCS units...www.transmissioncontroller.com
Old 02-26-2012, 01:18 PM
brad33478's Avatar
Looks like about $600 for those, TBI makes one with a display for $550 I may have to get
Thanks
4l60e swap bobbed500 Transmission - Rearend 2 08-23-2011 12:22 PM
4l60e with 350 carb? rustynail Transmission - Rearend 12 07-02-2010 06:17 AM
4l60e swap question dilllzz Transmission - Rearend 2 02-03-2010 08:56 AM
4l60e swap onto olds 350? rawcut Transmission - Rearend 5 07-01-2007 06:49 AM
4L60E Trans Swap MI2600 Transmission - Rearend 3 07-12-2003 11:36 PM
