383 chev motor in 1967 van what overdrive trans? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2010, 09:19 AM
Last wiki edit: Stroker 351 W Ford Motor=Building
Im installing a 383 chev motor in a 1967 van- im curious as to what overdrive trans i should install ?? 700r4 -200r or what - i want something that will last for towing and fuel mileage improvement. Thanx for any info.
Old 12-22-2010, 10:35 AM
Neither one of those will last very long in stock form. Either can be built to take the abuse, but it takes aftermarket parts to do it.
Old 12-22-2010, 11:07 AM
true=??
yes i am aware of that - yet which one is best??
Old 12-22-2010, 11:16 AM
"Best" depends on how you plan to modify it. The Turbo Buick community has found and fixed about every weak point on the 200-4R and upgrade parts are readily available. The nice thing about the 200-4R is that the trans is the same overall length as a TH350 or Powerglide. The trans mount location is in the same place as on the TH400. This makes is a bolt-in on earlier vehicles and you can usually find a stock driveshaft that fits. The 700R4 is unique in these dimensions. This isn't a big deal, it just requires drilling a few holes and having a driveshaft made.
The other fundamental difference is the gear ratios. The 700R4 has a steeper first gear, which might be better for towing. Unfortunately this also means that there's a big ratio drop between first and second. The 200-4R has more evenly spaced shifts.
Overdrive trans 1967chevelle454 Transmission - Rearend 3 04-10-2009 06:30 PM
Trans slips out of overdrive under NO LOAD? weirdbeard Transmission - Rearend 10 10-07-2007 11:40 AM
1967 Chev Van CHRISJEN Engine 3 07-15-2007 09:07 PM
overdrive trans for bb chevy truck Pycho baldy Transmission - Rearend 5 12-04-2003 05:24 PM
overdrive standard trans elkay65 Transmission - Rearend 1 01-19-2003 10:27 PM
