383 chevy 600 hp. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2007, 09:12 PM
383 chevy 600 hp.
i wish to do small block chevy 383 with 600 hp. and run on pump gas , possible or not possible ?
Old 01-16-2007, 09:25 PM
Sir Joab's Avatar
MOPAR Guy
Last journal entry: Restoration of my Chrysler
re: 383 chevy 600 hp
With or without super/turbocharger?
Old 01-16-2007, 09:31 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I think you're stretching your goals just a little bit... Your best bet is through the use of a supercharger or nitrous...
Old 01-16-2007, 09:38 PM
kuhn-77's Avatar
Build it right the first time
aluminum heads, and the max boost you can possibly run without detonation with an 8-71 blower
u just may have a chance, but thats with like initial 7.5:1 comp plus your boost to get that kind of power
Old 01-16-2007, 09:41 PM
kuhn-77's Avatar
your next option would be the N/A 600hp 605ft/lb trq World Products Motown 454 small block for $10,995
Old 01-16-2007, 10:00 PM
71C10's Avatar
U.S. Army Retired
http://www.chevelles.com/forums/showthread.php?t=156324
http://www.nastyz28.com/forum/showth...t=71913&page=2
http://speedtalk.com/forum/viewtopic.php?t=4877
More details in the March issue of HOT ROD...
Weekend warrior built as above in my "guesstimate" needs a minimum of 4:56 gears and 4500 stall...
Old 01-17-2007, 07:03 AM
firestone's Avatar
http://teamrfc.gospelcom.net
Some people may say that this is not possible, and I agree that it is a pretty tall task to beleive, but in the newest Hot Rod, the following motor was built.
383
does not say compression but they do say that it did this on pump gas so you can probably guess around 11:1 max.
AFR 195cc street ported eliminator heads
Speed Demon 850 carb
Victor Jr intake
Comp 287TKR-6 cam (259 264 @.050 .645 .630 106 lsa, numbers are with 1.6 rockers on the intake)
615 hp @ 6800 RPM
528 ft lbs @ 5100 RPM
And this is only the street ported heads that are ~$1450 a set. The comps which flow quite a bit better are available for $2000 a set.
Adam
Old 01-17-2007, 09:25 AM
Duke of Cruel's Avatar
Car nerd
Possibl n/a, but it will be very racey.
DoC
Old 01-17-2007, 11:12 AM
383 chevy 600 hp
without turbo or blower , carburator only and no nitrous , 11 to 1 comp. race alloy head and mecanic roller cam ,
a lot of my friends dont believe in this project !
Old 01-17-2007, 11:30 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
That's 160% power to cube ratio. That would put anybody into the engine masters challenge and national recognition easily.
The only way for you to conclusively prove it is to spend your $ 15,000+ to build it.
Without some seriously expensive parts that engine will be on the edge of explosion every time it revs. And it could not be considered a "street" engine by any stretch of the imagination.
Old 01-17-2007, 12:34 PM
Sir Joab's Avatar
MOPAR Guy
re: 383 chevy 600 hp.
Why not go Big Block? A 454 wouldn't be hard (in comparison) to get 600 HP out of. Or, if you have the money, you could build a Keith Black (www.keithblack.com) aluminum block 426 Hemi for under $15,000. That way you would have an engine with the weight of a small block, but the power of a large size Hemi. You can get all parts (somewhat) affordably in a Performance Automotive Warehouse catalog. (www.pawinc.com)
Anyway, that's my two-cents. Good Luck!
Old 01-17-2007, 02:02 PM
johnsongrass1's Avatar
Race it, Don't rice it!
A 4" bore 383 won't make that power naturally aspirated on any real life dyno. Don't matter what head you use.
Old 01-17-2007, 05:57 PM
71C10's Avatar
U.S. Army Retired
If you have the "cubic dollars" to pay for it, the answer is YES.
Check the links I posted earlier, "bigjoe1" in the forums at speedtalk.com is Joe Sherman.
Old 01-17-2007, 08:04 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Car Craft built a blown 355 running on E85 with TFS 215's that apparently does 601hp (but we all know that magazine dyno's are a touch "happy", maybe...) The whole build is likely availiable at www.carcraft.com, but the skinny is: Magnusson high helix 122 blower, TFS 215 heads, 10.2:1 compression, Crane Powermax 288 blower cam, Crane 1.6 gold race rockers, careful spark tuning, and E85 @ 105 octane. If you can believe the mag, detonation free. Price: $6,340.38 US.
Old 01-17-2007, 09:33 PM
MI2600's Avatar
Member# 3287
Another case of horsepower expectations creep. We started with 300hp, then 400hp, etc, etc.
The next post in this thread will be a guy who claims 700hp from his 283.
chevy 383 bent flexplate? 49chevysd Transmission - Rearend 3 01-07-2006 12:22 PM
hp of a 383 stroker mathjew Hotrodding Basics 5 11-02-2004 10:14 PM
Oil smoke or....? 383 Chevy Finmike Engine 8 07-08-2004 05:25 PM
1992 chevy 1/2 ton (383 Stroker) won't rev! dunegoon Engine 2 12-10-2002 08:41 PM
383 chevy motor 2 bolt mains wild1dude Engine 11 11-20-2002 07:45 AM
