Thread Tools Search this Thread share on Facebook
  #1
Old 03-22-2009, 06:39 PM
bracketracer bracketracer is offline
383 chevy with double hump heads
I need some advice on this, my 355 short block recently wiped out the bearings. My friend has a 383 short block with flat top pistons,I want to use the top end off my 355, its 461 casting heads, 64cc, 202 160 valves, cam is a solid lifter 256 264 at 50, 504 504 lift, intake is a victor jr, 750 holley vac secondary, how much horsepower will this make and how much compression will this be, also its a street strip car so mixing race fuel is ok. Thanks john
Register now (free) or login to remove ads
Old 03-22-2009, 11:20 PM
junior stocker's Avatar
junior stocker junior stocker is offline
383 with camel hump heads.
You're going to be up there on the compression ratio, and Hi-Test fuel will be a requirement. Be sure and get your "quench" set right from the start, somewhere in the area of .035 to .045.
Old 03-23-2009, 02:54 PM
We figured the compression will be close to 10.9, i plan on running 110 octane race gas, what kind of horespower could i be looking at with combo, is the double hump heads going to hold me back alot? I was running 12.30s with the 355 in my 3800 pound 55 chevy wagon with 4,000 stall and 4.86 gears. 28 x 10.5 slicks it would 60ft 1.65 and cross the finish line at 6300rpm, the stroker has a scat totating assembly, will it be safe to 6500. Thanks for your help.
Old 03-23-2009, 03:32 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
Location: In da woods, Union County, North Carolina, USA
Wiki Edits: 326
Static compression ratio will be 11.1:1 with flat-tops, 7cc's of valve relief and 64cc heads. Assuming this is a cast crank, the Scat cast cranks are cast STEEL, not cast iron, so I wouldn't hesitate to wind the motor to 6500 if it's kept out of detonation and is properly balanced.
Old 03-23-2009, 05:16 PM
Its a Scat 9000 crank shaft, and the rods are 5.7 summit stage one rods good for 525hp. Its been balanced but do you think those rods are the week link? He had aluminum afr heads on it that were 72cc and it was in a chevy two street car he took the heads off and used them on something else. Is 475hp realistic with those hump heads.
Old 03-23-2009, 05:59 PM
trees trees is offline
Did I miss what valves you have in your double humps? I can not remember if the 461s came with the larger intake valve as well. I think 475 would be realistic, but you could possibly do a bit of porting and approach 500. All this is a WAG based on what my 383 had when it had a milder cam and big valved 882 heads.
Trees
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "383 chevy with double hump heads"
ThreadThread StarterForumRepliesLast Post
educate me..double hump headsFASTFORDEngine408-22-2007 03:55 PM
327 with double hump headsbackyard71novaEngine402-13-2007 12:25 AM
Double hump heads85Iroc ZEngine512-30-2006 05:54 PM
350 with 327 double hump headsjulioandmariaEngine210-16-2006 03:48 PM
327 double hump heads on a 350 small blockrhibbsiiiEngine302-19-2006 08:59 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
