383 chevy small block stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2006, 09:01 PM
I would like to know if there is any difference in performance on rod length in these 383 strokers. I built this motor about 15 years ago when this combination was still kind of new. I used the short 400 rod and have a 144 B&M forced induction blower for it. It has forged pistons with 034 GM angled plug heads with 2.02 valves giving me about 8.5 compression. Now I have been thinking about changing the rods to the 5.7 rod and using hypertechtic pistons with may be a 8.0 comp. Would this be a good change and really improve my performance with the longer rod? or should I just stay with the short rod and save me some money. It runs a 470 lift cam with about a 274 duration. It will be going into either a '70 monte carlo or a 1963 chevy II. Any body have inputs on that. Would really appreciate any help. thanks!
Old 02-24-2006, 03:35 AM
Changing from 5.565" rods to 5.7" rods, a change of 2.4% in length, will probably be unnoticeable in your engine and its application. I would keep the forged pistons with the blower motor.
Old 02-24-2006, 06:38 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Save your money, "if" there is any measurable difference it would be so slight you'd never feel it.
Old 02-24-2006, 07:45 AM
NAIRB's Avatar
I wouldln't bother. Here is some straight talk concerning this over-blown issue.
Old 02-24-2006, 10:36 AM
Banned
I would stick with the shorter rods. Personally I like short rods, but it really doesn't mae a difference. Instead put the money into the ehads- heads can almost always use improvement.
small block chevy engine id code help princesswz Engine 22 01-03-2015 12:15 PM
big block or small block chevy 69YENKONOVA Engine 81 05-13-2010 08:26 AM
My 350 Small Block Chevy. What do I have? Frank the Tank Engine 29 09-08-2007 07:33 PM
Chevy 383 needs a small base circle? breall Engine 7 08-06-2005 04:04 PM
Why would you build a 383 small block chevy 454me Engine 15 06-19-2005 08:23 PM
