#1
383 chevy stroker in 71 olds cutlass
Hey guys, this is my first post on hotrodders, so I'm pretty new to this. But I'm currently building a chevy 383 stroker for my 71 cutlass, which has a olds 350 rocket in it. I haven't taken the engine out yet, so I'm wondering if I am going to run into any problems putting the chevy engine in the olds. Am I going to have to change anything with the mounts? Would it bolt up to the TH400 tranny I have in there? Any other problems I might run into? Any help/ info would be appreciated. Thanks guys!
Register now (free) or login to remove ads |
#5
You will need the frame mounts from any small block powered 70's ish Chevy, camaro, chevelle, monte carlo, caprice, etc. If your donor car has working transmission, grab it, otherwise you will have to get an adapter to mate the BOP trans to the Chevy. The starter on your chevy is on passenger side of the block, Olds is on the drivers side, so you will either need to relocate the battery to the passenger side, or buy longer battery cables. Headers from a 68-72 Chevelle will work. You'll need all the accessory brackets from a Small chevy, the olds stuff wont mount to your motor.
Save the original motor and trans, brackets, etc, you may decide to build that Olds motor, or swap in a 400 425 455 Olds(bolt in swap). |
#6
Thanks for the help guys. The reason why I'm switching it over to a chevy engine is because I found it much cheaper to rebuild a chevy than the olds engine and get the desired 450+hp. It doesn't seem too bad to convert though from what you guys are telling me.
Should still be cheaper to rebuild the chevy and do all necessary mods then to build up the olds engine? Right?? |
#7
It only costs a few hundred dollars more to build an Olds engine, and 455 cores can be had for $200-250 if you want an easy 450hp and 525lb/ft. The pulleys, waterpump, distributor, motor mounts, and accessory brackets from the 350 will swap over to the 455. The trans will bolt up, and with some minor upgrades(good shift improve kit and a fluid cooler) will work fine behind the 455. The only thing you cant do easily is find your parts in a Summit of Jegs catalog. Also, buying things like intakes and headers thru craiglist or other online sites(ebay, amazon) can save major dollars. I picked up a set of SRP pistons and CAT rods for $600, brand new in the boxes. $80 for a single plane intake, $40 for an early version of the Performer. The Olds 350 can be built the same way, and since you already have the motor, your already ahead. Just milling your heads and doing a multi angle valve job, and adding a tuned pair of headers will boost the 350 What gear ratio do you have in the car, just changing that to a mid 3.xx ratio would make a big difference in the cars performance. Most Cutass Supremes came with 2.56 gears during the early 70's Just throwing some alternatives out there for ya. Rememeber, Hot Rodding isnt about doing what everyone else has done, its about doing it your way. The world is bigger than Small block Chevys and Fords, and doing it differently is what makes you stand out, the car guy that people get to know and remember. |
#8
Another vote to stay all Olds, it really won't cost more to redo the 350 Rocket, especially with all the conversion parts and mods you need to do to use the chevy. Could also go to the big block Olds like suggested. Almost any time you crossbreed a car like this you will be lowering the potential resale value. People will pay more for the all-Olds version.
You picked the brand when you picked the body, stick with it! |
| Thread Tools | Search this Thread |
| Similar Threads for: "383 chevy stroker in 71 olds cutlass" | ||||
| 383 Chevy Stroker Valve Train Problem | acav383stroker | Engine | 4 | 04-09-2009 11:27 AM |
| 84 Cutlass, Chevy 383, How to wire a/c compressor | labreejr | Electrical | 15 | 12-09-2008 11:56 PM |
| 383 stroker kit (Ebay) | Hazard | Engine | 8 | 05-24-2006 06:51 AM |
| 383 chevy small block stroker | ZAPP59 | Engine | 4 | 02-24-2006 09:36 AM |
| Thanks for the 383 Stroker info | Ron Mexico | Introduce Yourself | 2 | 01-11-2006 11:05 AM |
