Thread Tools Search this Thread share on Facebook
  #1
Old 05-02-2009, 08:06 AM
63jd's Avatar
63jd 63jd is offline
63 NOVA SS
383 chrysler pushrod lenth?
will i need to check pushrod lenght with the block being decked or will the stock size work
Register now (free) or login to remove ads
Old 05-02-2009, 12:16 PM
cranky1's Avatar
cranky1 cranky1 is offline
Just stuck
How much are you decking the block? Stock lifter preload on a Mopar is around .060" If you have a little less, that's generally ok so if you have more, decking will make them want to go deeper and much more than .060 will probably keep the valves from fully closing. A lot of people rebuild their engines and use composition head gaskets and those are around .040 compressed. I mention that because they came stock with steel shim gaskets which run around .016-019 thick so if you are decking around .020 and plan on using compostion gaskets, you should be fine. Don't know how much you know about Mopars but make sure you reinstall the rocker shafts correctly or you might burn up the rockers.....
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "383 chrysler pushrod lenth?"
ThreadThread StarterForumRepliesLast Post
383 stroker v.s. 383 chrysler ...the endmcharger440Engine4209-07-2008 09:34 PM
383 Stoker vs 383 ChryslerJag DaddyEngine10008-14-2008 11:48 AM
383 chrysler blower manifoldlos locoEngine110-20-2005 10:42 AM
Chrysler 383 Suggestionssubman17Engine708-29-2005 11:03 PM
Top End Rebuild on CHRYSLER 383... HELP!Dizturbed OneEngine711-15-2004 04:50 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
