383 crate motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2006, 02:38 PM
383 crate motor
competition products has a 4 bolt 383 crate motor with aluminum canfield heads "195cc". they are 64 cc heads and yield a 9:7:1comprassion ratio 1 piece oil pan gasket, cloyes double roller timing chain, 202 160 valves,melling high volume oil pump w/ pan. externally balanced and topped off with a timing cover.by the way the heads also have a sergie 5 angle valve job on them. it comes with a howards cams 224/234 at .050 hydraulic cam, with performance push rods. the rotating assembly is all scat 4340. it goes for $3000 dollars, is this a good deal or should i consider another alternative. it comes with no warranty at all because it is a racing engine. what do you think?
Old 10-09-2006, 12:03 AM
Choctaw Bob's Avatar
The price is probably OK. Get a parts list from a online parts seller and add it up. Ask for the names of some people you can contact for reference.
I have bought crate engines before. I always disassemble them (I ask for the gaskets seperate) and clean them thoroughly. I check each component to verify that I'm getting what I paid for. I have found that mass produced engines are very dirty. They are sometimes dry assembled.
I assemble the engine with assembly lube, checking ring gaps, clearances, cylinder hone, and plastigage bearing clearances, I check piston deck height, block surface and heads for warpage. I've probably forgot something but you get the idea.
When you buy an engine without warranty, the only thing you can do to protect yourself is make sure it was assembled right. If you can read and pass high school math you are smart enough to read a manual. Even if you have never done it before, it is likely you will do a better job than someone working in a factory.
Old 10-09-2006, 03:54 PM
do you think i should just build a 383 out of the 3970010 350 i already have 2 bolt main, would this be better? there is a local hot rod shop that builds engines,they are top gun racing. i have no clue what it would cost to do this.i want a solid engine that will run for years to come. p.s. what about the 5 angle valve job, is this a good idea..............................help!
Old 10-09-2006, 06:57 PM
I just finished building my .060 over 402. I have done numerous engines over the years. I have a engine machine shop with a local high performance following. The high performance part is not really necessary but a reputable business that you can verify their quality work is essential.
I would use a 4 bolt main truck block. These are still in plentiful supply and relative inexpensive. send the block to the machine shop and pay him to check the mains and cam journals and block deck surfaces straightness. Have him check the crank centerline to deck. Everything should be within tolerance. Have him bore the block as necessary and hone it. Have him vat the block and install all new screw in oil gallery plugs and brass freeze plugs. and cam bearings, almost forgot.
Buy a crank, rods and pistons and moly rings as a balanced set. Have your guy fit the rings and set up uniform clearances on your bearings within factory spec.
Buy your heads complete with valve springs compatible with your cam. You can't save money here by buying them bare. A 3 angle valve job is fine for a street car and most racers. I thought a 3 angle was a waste of money for a street engine because you are talking about a very small amount of flow for the dollar spent.
Decide what you are going to use your engine for. If it is a street engine with a few blasts at the strip once a month, don't waste you money on a bilit crank. I like scat or renegade forged cranks. They are cheap and are better than most. You can build a pretty strong engine with a 350 forged truck crank. Buy scat or renegade H-beam rods. These are cheap and stronger than you will likely ever need. Buy Forged pistons. This is the most expensive part but the most critical. If you buy forged pistons, rods and crank, you can plop a blower or big nitrous on it any time as long as you keep the compression around 10 to 1.
Buy a quality set of aluminum heads. The old style heads, even double humpers are poor breathers compared to modern heads. I have a set of 65 dbl hump heads in the garage. They are so tiny. I will use them on a 32 coupe that will never be raced.
With all this said, if you are not going to race this thing much and never use nitrous, use the block you have, a stock crank, stock forged rods, hyperutechnic pistons and some iron dart heads. This will build you a stong engine that will be fun for less than $2,000 total.
Just don't ever drop one of the pistons on the concrete. It will shatter like glass. Like a dummy, I bought not one but 2 like this, this year.
I'm sure I missed something but get you a good book and read it thoroughly before you start.
Old 10-10-2006, 12:05 AM
327NUT's Avatar
To start with I really enjoy building my own engines, from the planning to assembly to hearing your baby cry for the first time, Chocktaw knows exactly what I mean. Now lets say you do buy that "racing engine" w/ no warranty, you have no idea how it was put together or the quality of parts that were used unless as said before you tear it down. Worst scenario....first time you wing it........POW!!! What recourse do you have?? None. Best scenario, the engine is put together perfectly with quality parts and runs great, you win, But......its not your baby. Do yourself a favor, if you are knowledgeable enough build the engine you have wheather a 350 or 383, you,ll enjoy it so much more, good luck with whichever you choose......Dave
Old 10-10-2006, 07:40 AM
Dave is right, I remember one of the most exciting things ever was when I was 16 years old, I bought a 56 Ford for $40 that had a rod knocking. I bought a junkyard engine and installed it myself in my parent's driveway, With no experience, just a Motors Auto repair manual, When the engine fired for the first time, I was like Dr. Frankinstein in the old black and white movie. "Its ALIVE! Its ALIVE"
Old 10-10-2006, 07:39 PM
thank you ever so much!
thank you guys from the bottom of my heart, i'll just take the time to build my own engine, aleady bought the 383 embelems for my 70 nova, now just got to get to work, what do yall think about a 268 advertised duration cam?
Old 10-10-2006, 08:52 PM
We build a lot of the 383's in the off season when every body is racing and we try to find the truck blocks that have the 2482 center caps on them as the are the GM performance cap if we can't find one we will convert the 4 bolt block to 3 center billet caps or even go to splayed caps in the center but the first thing we do is sonic test the cylinders for proper thickness.
Here is a link to a 383 we bulilt for a customer and tis engie had the AFR's but we have used the 906 vortec casting with very similar results and we used the same cam as well.
http://www.chevelles.com/forums/show...highlight=DYNO
Old 10-10-2006, 09:29 PM
jray's Avatar
Choctaw Bob is right...build it your self. Not only is that first fire-up a rush, you get the same feeling cruisn' and listening to that sweet sound and knowing it is something you created yourself.
Old 10-10-2006, 09:50 PM
Look at the cam that CNC NE used in the engine that made all that torque. Try to duplicate that grind. Just remember if there is any doubt, less duration is usually better on the street. You are looking for torque and a flat torque band that starts around 2,000 RPM and keeps it up til 5,000. High RPM Horsepower numbers don't mean a thing on the street.
Old 10-10-2006, 09:53 PM
You got that right J Ray, that big block Chevy singing through those roadster headers is the sweetest sound around.
Old 10-10-2006, 10:53 PM
327NUT's Avatar
Again .... for a good reliable, STREETABLE DAILY DRIVER 383 that has enough vacuum to work your power brakes I would recommend the Comp Cams XE268H.
Old 10-11-2006, 07:45 AM
I agreee with 327 nut that good vacuum is essential in a good street engine. If you run a Edelbrock or old Carter/Rochester Carb, you need a minimum of 12 to 15 inches of vacuum to hold the rods down so it won't flood. You can get by on a little less but not as reliably in all situations. I have 2 Edelbrocks that I tried to run with a 300 deg Comp cam that I owned. It made about 5 inches of manifold vacuum which wasn't enough with the lightest springs.
Old 10-11-2006, 09:09 AM
Be careful and don't get to small of cam as your DCR will be on the high side causing some detonation issues as we have seen this before on the 383 engines.
Old 10-11-2006, 12:59 PM
You can generally avoid this by keeping your CR under 10 to 1
10066036...350...2 or 4...Target Master/Goodwrench crate motor oldsmo Engine 8 05-16-2011 07:34 PM
GM crate Motor ? sbk12rs Engine 1 03-20-2005 10:27 PM
Cam choice for new GM 260hp crate motor Iceberg Engine 3 02-22-2005 12:03 AM
Price for an chevy blown crate motor? Etiene Coetzee Engine 3 07-30-2004 07:45 AM
ZZ4 HO Crate motor question Pepsimayn Engine 3 02-26-2004 11:08 PM
