Wet flowed or not, I'd suspect the PV is N/G, loose or gasket torn, etc. A 6.5 should be OK for it.
Do the routine for transfer slot exposure. Should you need a reminder, use the search function.
If that doesn't help, the idle bleeds may need opened up a little. Start w/0.002".
