Carb Defects
Carburetor defects can drive even a good carburetor man nuts. If the SOB is new, none of this crap is supposed to happen. I've got a 3310 750 that has the flaking metal issue(which turns in to a corroded POS)metal is so pitted up its junk. I was blaming it on the eythanol blended gas, till I picked up on the defect issue. Wonder if I could proof of purchase get a new carb?
LOL, You gotta use CHERRY chapstick on them gaskets, not just any chapstick. Ha |
http://www.holley.com/HolleyNews/article.asp?ID=174 |
It sounds like the supplier used TWO sheets of less thickness to form the gasket and depended on the press/punching of the gasket to hold the two pieces together.
Tanks
[QUOTE=Tech @ BG]My understanding from outside of the building was that the ones corroding were made with zinc from China that had a lot of lead content. Here is a link that may help you with the one you have.
http://www.holley.com/HolleyNews/article.asp?ID=174[/QUOTE Hey BG/Tech, Thanks, I might call summit and get my invoice # cause it was bought right in that time span. One of them shiny zinc thangs. When it started giving me issues and found the corrosion. I went dug a real old double pumper outa my junk pile, cleaned and kit, works good. Made when Holley still did em right. Oh, I thought the CHERRY chapstick was for cork gasket release and the blue ones were specifically marketed as reusable/non stick? What's your take on it, or were you born yet when us oldudes were using the cork? Tanks in advance.olnolan |
[QUOTE=OLNOLAN]
I've used PTFE resin in powdered form to make gaskets (not just carb) non-stick. It works well in most cases- and is better than nothing in ALL cases.
The powder I use came from a pyro supplier (it is used in some hyper-burst comps). It is also available from piano tuner/supply outlets. McMaster-Carr carries it in a 14 oz. aerosol, ~$10.00/ea. Better to my way of thinking, is to get it in 'bulk', that is, non-aerosol- just a container of the PTFE powder. For carbs, I've used it w/chapstick, tallow, lard, spray and liquid adhesive, "neat", white grease, vaseline, Pam, etc. All worked acceptably except neat and the adhesives. Don't use silicone or hylomar. A light coating of one of the above followed by a thorough coating of the powder will suffice. But the surfaces must be clean, w/no old gasket material left behind- at all. It sometimes helps to have the carb warm when it's disassembled- this is true whether or not the gaskets have been treated, and seems to work the best w/the "non-stick" gaskets. Just DO NOT warm a carb in your food oven! A hot air gun will suffice. Try it on a bowl and see if it helps. If it does, use it for the remaining gaskets. |
try a different ignition module , it almost sounds the module is'nt changing the dwell with the engines rpm's. it's rare to get 2 bad carbs , especialy 2 different name brands or try another distributor.or maybe try dropping the feul pressure down 1 or 2 psi.
| acceleration flat spot in carb. | corvettetonybone | Engine | 17 | 04-13-2013 08:31 PM |
| 670 Truck Avenger Holley Qs | gawdzilla | Engine | 7 | 02-21-2007 11:30 PM |
| Major Carb Failure - Street Avenger | dev | Engine | 9 | 12-03-2004 06:39 AM |
| Holley Carb Tuning | Coleman396 | Engine | 4 | 07-19-2003 10:03 AM |
