383 EFI or Carb? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2009, 07:48 AM
383 EFI or Carb?
I have been thinking about this for a long time. I have a couple of different set ups. Engine specs are :
383 2 Bolt
9.5 Compression
Patriot 190 cc Aluminum Heads, 62cc
218/224 @.050 .495/.502 lift 112 lsa, 110 ICL
Edelbrock 3594 fuel pump
Shorty Headers with 2.5" Y into single 3" flowmaster no cat
This is a 1 ton 4 by 4 truck. It came factory with TBI injection. the last set up had holley tbi with fuel pressure turned up alittle. I ran lean. this is waht i have for induction:
1. Edelbrock rpm intake with holley 2" thottle body
TBI chips chip
65 LB Injectors
2. Edelbrock 3501 mpfi for tbi system ( got a great deal on ebay its brand new)
29lb injectors
holley 502-6 as air valve ( no injectors)
To make the 3501 kit work proper, I am going to have to buy a different computer to run in port firing. Learn how to tune it, etc. I wanted to keep it fuel injected because everybody i talked to said it wouldnt run right. Now I just want to get it on the road. I like the idea of fuel injection, i am not sure i like the idea of tuning it. So to the question, which system should i go with? Will a carb out perform efi? What would u do? Money is not behind my thinking. Just want some input on what the other hotrodders think. Thanks in advance.
Old 11-21-2009, 08:34 AM
DoubleVision's Avatar
There is no carb that comes close to injection, hands down. However if you don`t want the hassle of tuning it and just want to get it on the road then by all means stick a carb on it, tune it, and be on your way. You answered your own question on that one.
Old 11-21-2009, 08:43 AM
thanks for the reply.
Old 11-25-2009, 11:51 AM
So I decided to go with the multi port. I went to put on the intake this mourning, and the middle bolt holes are off. I think the patriot heads are drilled like the old sbc heads. Can I widen these hole out? Thanks for the replys.
Old 11-25-2009, 12:27 PM
Banned
Originally Posted by DoubleVision
For milage and responsiveness There is no carb that comes close to injection, hands down.
Carbs still make more power- varrying from only a little to a significant amount.
Old 11-25-2009, 07:02 PM
Last wiki edit: Hand cleaner Last photo:
Wiki Edits: 3
you should be able to slot the holes and use washers under the bolts with some silicone.
you may want to look into the EBL for the ECM.
http://www.dynamicefi.com/
i hear a lot of people say that, but the fastest cars are fuel injected
Old 11-25-2009, 11:00 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I wonder why top fuel run fuel injection if carbs make more power? If you want a bolt on and go carb is the way but if your after the quality of cold starts, idle, tuneabilty, flexibility, economy, and performance i would go fuel injection. I love going to the track and seeing people sitting in their car changing the timing and pulse width by just sitting there using a laptop and not spilling fuel by changing the jets. There is no way a regular dist with vacuum and mechanical advance and a carb can account for all the different operating conditions of an engine. just my .02 but i have lots to learn still
Old 11-26-2009, 11:42 AM
Thanks for the replys. Yeah I think i keep it injected. I am still working on the maniflod, try to mak it fir those patriot heads. Those top fuel race cars would have to be injected because of the boost. Just a thought, thanks again.
Old 11-26-2009, 12:12 PM
302 Z28's Avatar
Not in all cases, you cannot make a blanket statement like that. Just like anything the EFI system can be sized to take maximum advantage of all a particular engine is capable of and do it over a very wide RPM range to boot.
Vince
Old 04-10-2010, 07:17 AM
I have a Holley Multi-Point Fuel Injection system for sale with a 950 commander computer.
http://www.hotrodders.com/ads/showproduct.php?product=7308
Thanks,
Rob
Old 04-10-2010, 04:02 PM
Even so this is a bit of a older post, it don`t bother me any what AP says if he`s right or wrong, he seems to like letting me know if he thinks I`m wrong about something and it`s cool, even so i`m not in competition here.
AP`s a good kid and he`ll get wiser as he ages, I have hope for`em lol.
Old 05-25-2017, 04:34 PM
Looking for ***************
I know this question comes about 8 years late... but, I was curious if you still have the********************I'm looking everywhere for one.
Last edited by 68NovaSS; 05-25-2017 at 04:47 PM. Reason: Request for parts, not allowed, use PM's
Converthing EFI to carb (s-10) help... ForceFed86 Hotrodding Basics 5 10-13-2009 12:31 AM
1988 ford efi to carb swap specifics? kunstler Engine 8 03-24-2007 09:28 AM
CARB. VS. EFI khaotic89GT Engine 5 05-19-2003 04:39 AM
S-10 wiring 2.8 EFI to 350 carb S_10_HELP Electrical 2 02-23-2003 07:12 AM
