Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 Engine Build
Old 06-11-2013, 08:06 PM
lhmurphy's Avatar
lhmurphy lhmurphy is offline
383 Engine Build
Parts list:
Scat40805BI Includes-(Forged Icon Pistons +19.6cc)
Forged Scat Crankshaft 3.75 Stroke
Forged Scat I beam rods
Block: Dart SHP 4.030 Bore, Zero Decked, Ready to assemble
Cam Kit: Comp K12-772-8 (Solid Roller) @.05 248/256 Lift: .576/.582
Parts Stack Height: 9.000
Compression Ratio: 9.5:1 with 64cc combustion chambers
Head Gasket Thickness: .039
I'm currently looking at bolting on a set of AFR 1054's to top this engine off. My plan for this motor is to use it for mud bogging. My dilemma is that I want to bolt on a set of heads that can really match this cam and make this motor push 550 horsepower to really spin all four of the 35 inch mud tires. Rear end is a 3.73 gear and plans to go to 4.56 are coming soon. Any advice to what set of heads, or cam change would be appreciated. I also want to be able to run no higher fuel than 93 octane but if alcohol is needed to raise HP and torque a reasonable enough amount to justify running it then I'm all for it. Thanks in advance.
