Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 Engine Build
Old 06-13-2013, 04:55 PM
lhmurphy's Avatar
lhmurphy lhmurphy is offline
Originally Posted by oldbogie View Post
The small base circle helps with rod clearance on the stroker engines, when the cam starts getting a lot of lift on the lobe this gets to be a problem even with cap screw rods and 12 point bolts. On the down side a small base circle cam is more prone to whip when using strong valve springs.
Bogie
I knew that but I think with the stroker clearanced scat I beams I won't have trouble with cam to rod clearance. At least I hope I get enough clearance or I will be shippin a cam back! Lol
