383 Engine build questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2011, 03:56 PM
Hey all!
i decided to build my first 383 stroker from a Vortec block. Im piecing it together. I already have got a set of Lunati solid roller lifters. I am going with Vortec Heads on it. I have a set of 062's with new springs, keepers, and retainers from alex parts.com that allow up to .550 lift. The cam i was thinking of going with to maximize the lift is COMP Cams 12-702-8. What im a bit foggy on is whether i would want to run 1.5 or 1.6 roller rockers?
It will be in a race only s10. i want to up the compression to 14 or 16 to 1 and run on e85. plan to run a 4000 stall or so
Old 11-13-2011, 01:53 AM
that is one crazy set up but use the 1.5
Engine build questions 75chev4x4 Engine 42 01-29-2011 10:05 AM
Yet another 383 build up, questions olmanburns Engine 4 07-08-2010 11:15 AM
noob engine build questions chevy1500z71 Engine 8 02-24-2009 07:44 PM
200-4r experts - build questions - Which core is best to build on? Warrant Transmission - Rearend 7 10-09-2007 07:36 PM
Engine Build Questions BennyDigitale Engine 13 11-23-2006 11:03 AM
