Well fellas I started out on this build about 13 months ago and slowly bought all the parts for this 383 stroker to drop into my 72 chevy p/u. I'm finally finished with the motor, and when I ran the motor for the first time it sounded like a beast! I was using 93 octane fuel. Anyway, I ran My numbers through the desktop dyno and I believe that this is too good to be true so I'd like some professional opinions on expected compression ratios, HP, and TQ (for someone else out there who knows how to run a desktop dyno better than this dummy! I've included every morsel of info I thought would be pertinent. Any help is appreciated. Thank again guys and pics and video to follow!
-Josh
Block: 3970010 .040" over honed, sonic checked
Crank: Eagle 103503750 - 3.750" stroke
Pistons: Sealed Power 8KH100CP40 - 4.040" flat top with 2 valve reliefs
Rods: Stock 350 Rods signed off on by the machinist, press in wrist pins
Bearings: Mains - Sealed Power 4663MA - Bi Metal Bearings
Rod - Sealed Power 87100CH - Tri Metal
Pushrods: Proform 66891C - 1 Pc oiler pushrods
Valves: Manley 1.94 and 1.60 with 3 angle faces
Springs: Comp Cams 986-16 (as req'd per cam card) - 332 lbs/in
Heads: 462 Cast Heads, ported, polished
Head Gaskets: Fel Pro 501 SD
Rocker Arms: PSP Performance? 1.6:1 Roller Rockers
Timing Chain: Edelbrock 7801 - Double Roller Setup
Cam/Lifters: Comp Cams 12-250-3 XE 284H Grind Hyd Flat Tappet
110 LSA 106 Centerline
Duration: 284 I / 296 E
Duration @ 050" Lift 240 I / 246 E
Valve Lift: .507 I / .510 E
I'll have to find the damn cam card for the rest
Intake Manifold: Professional Products 52010 Air Gap Equiv. to Edelbrock,
Dual Plane High Rise
Carb: Holley Street Avenger 770 CFM Vac Secondaries and Elec Choke
Headers: Homemade 2" long tube
-Josh
