383 flexplate/balance plate/converter question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2011, 06:41 PM
I have a 383 sbc. I am almost done putting it together. Im putting a non-balanced 350 flexplate on the back and was told to use a 400 balance plate. but when I put the converter on, the 400 balance plate blocks one of my converter holes........what do i have wrong? I know that there is only one way to put the 400 balance plate on and Im 99% sure I have it on right......I called the speed shop that I bought the balance plate from and he said "never heard of that happening" ??????? any assistance is greatly appreciated.
Old 02-14-2011, 06:49 PM
another thought.......
should I just go to a 400 balance plate and forget it? and if i go to the 400 balance plate, then does it have to be internal balance, or external (not sure on the difference)......
Old 02-14-2011, 07:38 PM
is this the wrong area for this question???
Old 02-14-2011, 08:32 PM
ericnova72's Avatar
More for Less Racer
Smart move would be to use an 400 flexplate, which is external balance, so that you don't have to use the add-on balance plate.
The add-on plate is intended to be used with a internal balance flywheel for guys that are using a clutch and manual transmission where external balance flywheels are harder to find than external balance flexplates are. Not really intended for use with a automatic transmission flexplate, as you have found. The plate allows them to use an internal balance flywheel on an external balance engine.
Old 02-14-2011, 08:42 PM
ok, so a starter change is needed then......what about my torque converter?? can i still use it with the 400 flexplate, or do I have to get an different one?
thanks for the reply
Old 02-14-2011, 08:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The torque converter will work w/either type flexplate.
You are sure the engine is externally balanced, right?
700R4 Torque Converter Flexplate Question fosterdl Transmission - Rearend 8 03-23-2008 12:03 PM
Flexplate Question regarding Balance leejoy Engine 6 01-07-2007 06:52 PM
TH350 gap between converter and flexplate QUESTION chrisgarrison Transmission - Rearend 6 12-26-2004 11:32 PM
700r4 torque converter to flex plate question BR57 Transmission - Rearend 6 10-05-2004 12:41 AM
351 Flexplate Balance k2mooch Engine 2 12-27-2003 02:27 PM
