383 flywheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2011, 06:16 PM
383 flywheel
Hi guys need some help with a 383 sbc external balanced. i bought a 383 stroker out of a boat with hardly any hours on it and it has a 400 style balancer in front and i bolted it to a neutral balanced 153 tooth flywheel on a t5 tranny. i fired it up and it viabrated pretty bad at 3000 rpm. should i put a balance plate from jegs in it or could i weld or bolt the weight from a 400 flexplate to it. i would rather not pull it. thanks again gents..........
Old 10-03-2011, 05:18 AM
poncho62's Avatar
Wiki Edits: 5
You need a Chevy 400 externally balanced flywheel/ring gear
Ontario Rodders
Old 10-03-2011, 05:23 AM
2X on the balanced flywheel.
gm flywheel stans56 Transmission - Rearend 4 08-26-2010 07:46 PM
LT1 flywheel rwc112 Hotrodding Basics 1 08-12-2009 10:50 AM
FLYWHEEL question: t-5 (V8) and 4.3L 5 spd flywheel boneyard Buick Transmission - Rearend 1 07-20-2009 09:43 AM
1-piece sbc flywheel vs LT1 flywheel curtis73 Engine 2 12-02-2007 05:02 PM
FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? boneyard Buick Engine 0 11-17-2006 07:20 PM
