My 400 in my 1979 1/2 ton Chev is in need of work. Basically everything except the bottom end. So i'm thinking of building a 383. What will I need for a good medium range engine. Comp. ratio? Heads? Pistons? Intake? Cam ect.. I want to do it right. But I don't konw anyone who has built one.
Get the AFR catalog and build the one in the back
Buy a Chevy over the counter crate motor (See you local chevy dealer). Saves time, money and busted knuckles. These engines are really nice.
Why not use what you have? Rebuild your 400, install 350(5.7") rods, Edelbrock performer cam and intake, or similar. Keep the compression down, around 9.0 to 1, unless you use aluminum heads or can afford expensive gas. You will need to check for rod to cam lobe clearance. Your machine shop will know how to do this.
[ April 10, 2002: Message edited by: trophy ]</p> |
Medium stroker bore 30 over flat top pistons hypertech 350 block 4 bolt main preferably you got to notch the block bottom of cylinders for clearance rod bolts also MUST be ground for cam clearance have crank assembly balanced they should do the grinding for you tell them what your doing you'll be alright with stock crank my opinion cam 470 lift 68 to 72cc heads valve size your pick dual plane intake 600 to 650 carb should get what your looking for should set you back about 1600$$
just built a 383, thing runs its assphalt off,but you could buy a crate motor for less and save time. i just wanted to experience building my own, i did it and glad thats over!
teamtazdragracing has a good idea get a crate motor. Heres the site for GM. They have a 383 I belive. Check the performance catalog also.
http://www.gmgoodwrench.com/dhtml/index.shtml :p
Luv the smell of NITRO in the morning. |
FYI, Summit has 5.7's with recessed rod bolts just for 383 applications.
Try checking with local parts stores, performance shops, and performance parts companies. Most of them have a 383 kit for all sorts of power ranges and prices. All you would need is a 350 block bored .030 over.
I built a 383 for my 84 4X4 Suburban. I pieced it together from several different motors that I had. It ended up being a killer torque motor. I had Edlebrock build me a cam just for my application. The 383 needs smaller lobes because of the longer stroke in the 350 block. I gave them all the pertinent information like vehicle weight, type of trans, gear ratio and they built a cam just for me. Works GREAT! Those 2.02/1.60 double camel hump heads help it breath. It came out 375 HP and a whopping 455 Ft.Lbs of torque. I'm running the truck 4sp tranny (1st is granny). While I had the motor out I put 73 1ton 4X4 axles and springs under it too. With my parts the machining and motor assembly cost me $2200. The GM truck 383 with 325Hp and 415 FtLbs costs over $3700. Hit those swap meets or your local junk yard and start scrounging, that's what I did.
Good Luck, Vic |
