Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 hesitation
Thread: 383 hesitation
  #22 (permalink)
Old 11-27-2012, 08:19 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by jaw22w View Post
One problem still persists. When I drop it in gear, it wants to die. Am I running into the transition slot thing?
Usually you wouldn't be into the transition slot w/that much initial timing. But I suppose the possibility exists.
Start by readjusting the idle mixture screws. Do that first and see what it runs like. If that doesn't help enough, the easiest way to see what the t-slot looks like is to remove the carb and turn it over (careful of the fuel coming out of it).
Hopefully the problem isn't a too-tight torque converter. Does it try to pull through the converter when at a stop, foot on the brakes?
The Following User Says Thank You to cobalt327 For This Useful Post:
Custom10 (11-29-2012)
