Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 hesitation
Thread: 383 hesitation
  #30 (permalink)
Old 11-27-2012, 10:44 PM
jaw22w's Avatar
jaw22w jaw22w is offline
Custom10. I made a small L bracket from 16 gauge sheetmetal, about 1/2" long on each leg, with a hole in one leg of the L. I threaded the hole to 8-32. Then I welded the other leg of the L to the vac adv base plate with the hole looking at the vac rod. Then screwed the 8-32 x 1" bolt in so that it would limit the movement on the rod. Then used a lock nut to lock the 8-32 bolt. Now I can screw the bolt in or out to limit the vac adv to whatever I want. Does this make sense to you?
