383 hesitation - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 11-27-2012, 09:47 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
nope, got a camera?
  #32 (permalink)
Old 11-27-2012, 09:56 PM
jaw22w's Avatar
yeah, I have a camera and can download the to my computer, but I have no idea how to get them on here. I am barely able to turn on the computer and get to the sites I want. Something about old dogs and new tricks?!?!?
  #33 (permalink)
Old 11-27-2012, 09:59 PM
Custom10's Avatar
Look I have spent allot of time on this **** and your thread. How does the limiter plate come in contact with the rod? If it raises the rod in towards the can in a static no vacuum condition then it also moves the reluctor each time it is adjusted. If it comes in contact with the canister rod on the can side then it does nto change the relucktor position when adjusted.
I asked you how 14 deg, so this method of yours contacts the rod in what fashion, by pushing the rod towards the can in a static position or by stopping the rod travel at the far end? help me out here
  #34 (permalink)
Old 11-27-2012, 10:03 PM
jaw22w's Avatar
this is a test to see if I have figured how to post pictures
  #35 (permalink)
Old 11-27-2012, 10:06 PM
jaw22w's Avatar
I guess not yet.
  #36 (permalink)
Old 11-27-2012, 10:07 PM
Custom10's Avatar
No problem old dog Jim
TJ
  #37 (permalink)
Old 11-27-2012, 10:14 PM
jaw22w's Avatar
the adjustment bolt is between the upturned end of the rod and the can. The bolt is parallel to the long portion of the vacuum rod. As the vacuum comes in and the upturned end of the rod moves toward the can, the bolt contacts the upturned end of the rod and stops its movement, thus limiting the amount of advance. I hope this makes sense. I have attempted to post a picture, but was unsuccesful. I will work on it.
  #38 (permalink)
Old 11-27-2012, 10:33 PM
jaw22w's Avatar
Trying to post a picture
  #39 (permalink)
Old 11-27-2012, 10:35 PM
jaw22w's Avatar
yeah! got it figured out now.
  #40 (permalink)
Old 11-27-2012, 10:43 PM
jaw22w's Avatar
That was so much fun,I think I'll post a picture of my car. Completely built from scratch at home.
  #41 (permalink)
Old 11-27-2012, 10:48 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Posting photos: How to post pictures and videos on Hotrodders.com
Edit- just saw you figured it out.
Pump free play at WOT:
Basically, you want zero play at rest, foot off the gas pedal.
With the throttle opened wide open, there has to be about 0.015" play so the pump diaphragm isn't damaged from the linkage over-traveling.
The adjustment is made using the small bolt/spring that contacts the pump arm and a feeler gauge (see below). This photo is one that shows the feeler, etc. good, but the adjustment bolt and nut are upside down plus don't look to be original (shouldn't be slotted). Assembled correctly, the adjuster nut, bolt, and spring should look like the second photo.
Holley's instructions on the shooter and cam are on page 6 and 7, here.
  #42 (permalink)
Old 11-27-2012, 11:00 PM
jaw22w's Avatar
Cobalt327, OK I think I got it. I just scanned the Holley instructions. They definitely deserve a good read.
Thanks
Jim
  #43 (permalink)
Old 11-27-2012, 11:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Just wanted to say I'm always glad to see you here when things about the adjustable vacuum advance, etc. comes up. Good job w/all that.
  #44 (permalink)
Old 11-27-2012, 11:25 PM
Custom10's Avatar
OK that is 1000 words, stoped on the can side of the rod travel. OP you seem to have a good handle on timing, I am wondering why U would mention not to hook up the vacuum advance when U have spent so much time on that gizmo? nice job by the way.
  #45 (permalink)
Old 11-27-2012, 11:27 PM
jaw22w's Avatar
It's late. I'm going to bed. Just wanted to say that I cannot express my appreciation for all the time Cobalt327 and Custom10 have put in on my problems today. Thanks for your patience with me.
Thanks,
Jim
hesitation 1966 CHEVELLE Engine 1 04-07-2010 05:01 PM
383 Hesitation mightycarlo10 Engine 12 08-11-2008 07:11 PM
Hesitation! frankenvette Engine 17 05-18-2006 04:55 PM
Hesitation 1969NovaSS Engine 5 08-01-2005 09:11 AM
hesitation corenele Engine 16 08-13-2002 11:38 PM
