383 horsepower - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2011, 10:29 AM
383 horsepower
could anyone estimate how much horsepower for my 383 stroker. scat crank,eagle rods,speed pro dish pistons,procomp single plane high rise intake, 750 holley carb,305 heads that have been bored out with comp springs,282 comp cam,accel distributor and stock style cap and 65,000 volt coil.
Old 08-10-2011, 01:05 PM
cool rockin daddy's Avatar
1.21 giga-watts???!!!!
You put 305 heads on a 383?
Old 08-10-2011, 03:16 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
aren't those the bast**d step children of chevy performance
Old 08-10-2011, 08:31 PM
Why yes, yes they are. This guy's all over the map. Says he's gonna get aluminum heads in another thread and just started one about turbos.
Old 08-10-2011, 09:44 PM
bigdog7373's Avatar
Of course it's fast
Cam specs? So we dont have to search and look it up please. Compression ratio? Valve size?
And again 305 heads on a 383??? Are you on crack?
Old 08-10-2011, 10:16 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
At least he bored out his heads...
Old 08-10-2011, 11:04 PM
bigdog7373's Avatar
Of course it's fast
I was hoping someone else would see that
Old 08-11-2011, 12:16 AM
F-BIRD'88's Avatar
Yada Yada Yada
Your very limited detail of the parts doesn;t allow a good estimate of the power output of the engine.
One critical are is the port flow and valve sizes of the (305) cylinder heads.
What I define as a souped up hot rodded 305 head for a 350 may be very different than what you really mean and what you got there.
In stock form a "305 head" creates has very modest power.
What you do with it from there to improve it, makes or breaks the motors power potential. Some of the 305 heads can be made to make good power with work. Some others are more limited.
What is the casting number?
If the "305 heads" are not generously ported with larger valves don;t expect huge power.
Another is the compression ratio.
you make no mention of the exhaust system
more detail on the camshaft.
Old 08-11-2011, 12:03 PM
327NUT's Avatar
Oh no!!!! with them bored out heads he pushin somewhere between 200-500 hp.
Old 08-11-2011, 04:36 PM
bigdog7373's Avatar
Of course it's fast
Fbird, he doesnt mention the cam specs, compression, or exhaust, because mostly likely the engine doesnt exist. And he just going to keep throwing out different combos til he feels satisfied.
Old 08-11-2011, 09:12 PM
383 hp
I've been doing engines/cars/racing/dyno's/carbs/injection/ignition systems of all kinds for more than 50 years and along the way have learned a few things from reading/doing/asking questions, etc. I'll gladly try to help anyone that wants to learn. I don't have all the answers but can usually direct them to someone that does have the answer. However, I really resent anyone wasting my (our) time when their too damn lazy to learn on their own and only want to BS someone.
(Jumped down off my soapbox)
Ron
305 horsepower chevysscamaro Engine 8 09-22-2008 11:22 AM
SBC Horsepower ? sgunlock Engine 26 04-04-2008 07:36 PM
How Much Horsepower Do i have?? badassclassic572 Engine 2 09-12-2007 07:59 PM
Horsepower Help M@MRACING Hotrodding Basics 1 06-03-2004 10:46 AM
Horsepower.... and horsepower loss PonchoTA79400 Engine 3 03-13-2004 09:25 AM
