383 Ideas/Help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2008, 09:13 PM
monte-ss's Avatar
383 Ideas/Help!
Im trying to plan building a 383 here is what I have to start with.
89 L98 350 block roller cam set up.
10088113...88-up...350..........Aluminum, 58cc, angle plug, raised "D" port exhaust, 1.94"/1.5" valves (cut that out of the MORTEC website)
I have 1.6 full roller rockers and the exhaust port on the heads has been opened up a little to match the headman super comp headers.
The intake is a TPI system using SLP larger runners and the intake system has been ported and polished as well.
and a 700R4 trans thats been rebuilt with a shift kit and extra clutches in each pack.
Looking at a street with very occasional strip use but mostly something fun to ride on the weekends and so forth possibly daily driver to and from work. The engine is going into an 87 Monte Carlo ss with a ford 9" at about 3.50+/- gearing.
Im thinking 383 5.7 rods with dished pistons to lower the compression ratio with the heads. Not sure what cam to use and if I need to go with forged components, if its over kill or not. Wont ever be putting NOS or a supercharger on it (already tried the supercharger wasnt all that impressed).
Thanks for your help in advance.
Old 08-01-2008, 11:48 AM
327NUT's Avatar
Theres a million threads on 383's, do a search and you should find all the info you need.
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 08:08 PM
383 Stoker vs 383 Chrysler Jag Daddy Engine 100 08-14-2008 11:48 AM
Supercharging and fuel injecting a 383 Chevy Noesis Engine 11 09-21-2007 05:51 AM
383 0r 406??? Zubair Engine 60 10-14-2005 07:53 PM
What makes a 383 so much more expensive? Chevy21 Engine 12 09-30-2004 08:55 PM
